Sburel
dynamic concatenation of checkbox list output in the same window
I trying to create a simple script where, as various items in a checkbox list are selected in a window, those items are concatenated and displayed dynamically in the same window below the list.
Eventually, I would have a series of checkbox lists whose results are concatenated into a string.
Any suggestion would be appreciated,
Best,
sebastien
New Window( "Example",
cb = Check Box( {"One", "Two", "Three"}),
text box( "Selected: " || Concat Items( cb << Get Selected(), ", " ) )
Re: dynamic concatenation of checkbox list output in the same window
Here is the simple modification to you code to make it work
Look to the Scripting Index to help understand the elements of the script
	cb = Check Box(
		{"One", "Two", "Three"},
		tb << set text( "Selected: " || Concat Items( cb << Get Selected(), ", " ) )
	tb = Text Box( "" )
	cb = Check Box(
	tb = Text Box( "" )
Sburel
Thank you!
