29755
Fit Special Limits JSL
Hi all,
I am using Fit Y by X Plot and I need 3 limits on my plots (Control Limit, Upper Limit and Lower Limit) where I used the fit special 3 times and input the slope and intercept needed. But I don't know how to do this in JSL. This is only the output I get when I save the script to script window
Bivariate(
	Y( :Age ),
	X( :Sex ),
	Fit Line( {Confid Curves Indiv( 1 ), Line Color( "Black" )} ),
	Fit Line( {Line Color( {196, 189, 43} )} ),
	Fit Line( {Line Color( {39, 174, 174} )} ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{DispatchSeg( Line Seg( 1 ), {Line Color( "Black" )} ),
			DispatchSeg( Line Seg( 4 ), {Line Color( "Black" )} ),
			DispatchSeg( Line Seg( 5 ), {Line Color( "Black" )} ),
			Row Legend(
				Blade Type,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
		Dispatch( {}, "Linear Fit", OutlineBox, {Close( 1 )} ),
		Dispatch( {}, "Linear Fit", Outline Box( 2 ), {Close( 1 )} ),
		Dispatch( {}, "Linear Fit", Outline Box( 3 ), {Close( 1 )} )
Is there any way I can input or customize the intercept and slope values using JSL?
Re: Fit Special Limits JSL
Here is a saved script using JMP 16, after setting one of the Fits to a Fit Special.  It shows how to specify the required JSL
names default to here(1);
dt=open("$sample_data/big class.jmp");
Bivariate(
	Y( :Age ),
	X( :height ),
	Fit Special( Intercept( 0 ), Slope( 1 ), {Line Color( {212, 73, 88} )} ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			Row Legend(
				Blade Type,
				Color( 1 ),
				Marker( 0 ),
				Marker Theme( "" ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
