newbie_4
different spec limits for different variability plots
I am trying to create variability plots and show spec limits with values specified in LCL and UCL columns. I need different spec values for within graph (based on ROUTE_TYPE column, FL and SL have different limits) and for 2nd variability plot (for OVL_UNL parameter, L2_L1 has different FL/SL limits vs L3_L2)
Thanks
Re: different spec limits for different variability plots
To accomplish this you will need to use << Add Graphics Script to the Variability Chart, that reads the LSL and USL values an then adds them as lines to the chart.  The script below is an example
dt = New Table( "Example",
	Add Rows( 12 ),
	New Column( "age", "Ordinal", Format( "Fixed Dec", 5, 0 ), Set Values( [12, 12, 13, 13, 14, 14, 15, 15, 16, 16, 17, 17] ) ),
	New Column( "sex", Character( 1 ), "Nominal", Set Values( {"F", "M", "F", "M", "F", "M", "F", "M", "F", "M", "F", "M"} ) ),
	New Column( "Height",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 12, 1 ),
		Set Values( [58.6, 57.3333333333333, 59, 61.25, 62.6, 65.2857142857143, 63, 65.2, 62.5, 68, 62, 69] )
	New Column( "LSL",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [45, 45, 50, 50, 57, 57, 60, 60, 60.5, 60.5, 61, 61] )
	New Column( "USL",
		Numeric,
		"Continuous",
		Set Values( [60, 60, 65, 65, 67, 67, 70, 70, 72, 72, 75, 75] )
vc = Variability Chart( Y( :Height ), X( :age, :sex ), Std Dev Chart( 0 ) );
Report( vc )[framebox( 1 )] << add graphics script(
	For( i = 1, i <= N Rows( dt ), i++,
		xstart = (:age[i] - Col Min( :age )) * 2;
		If( :sex[i] == "M",
			xstart = xstart + 1
		Pen Color( blue );
		Pen Size( 2 );
		yMat = Matrix( :LSL[i] || :LSL[i] );
		xMat = Matrix( xstart || xstart + 1 );
		Line( xMat, yMat );
		yMat = Matrix( :USL[i] || :USL[i] );
		Line( xMat, yMat );
	Add Rows( 12 ),
		Numeric,
		"Continuous",
	New Column( "LSL",
		Numeric,
		"Continuous",
	New Column( "USL",
		Numeric,
		"Continuous",
		If( :sex[i] == "M",
			xstart = xstart + 1
		Pen Color( blue );
		Pen Size( 2 );
		Line( xMat, yMat );
		Line( xMat, yMat );
