optoman
data normalization
Hi All,
I'm very new to JMP. I am using 9.0.3 version.
I want to normalize my data, using one of the cells in the same data set.
Is there a function/script to do this ?
Thanks for your help,
Ozan.
ron_horne
Re: data normalization
Hi Ozran,
in the Formula Editor for a column you can get built in references to many typical values of a variable by selecting "statistical" group of functions (i.e. col mean, col median, col max, col min and so on).
if you want to give a reference to a specific cell that is not the a regular parameter of a variable you need to slowly click twice in formula so it becomes a script and ad the number of the row in [].
for example, this column formula will divide each cell of the column "60 min" by the 25th cell of "90 min"
:Name("60 min") / :Name("90 min")[25]
Remember though that JMP is Not a Spreadsheet.
ron_horne
Hi Ozran,
optoman
Thanks Ron. It worked.
sbarnes
Thank you! That was a huge help.
