jfendrich
data labels?
How do I add labels to data points in plot? Can I choose which column are used as the label
Jeff_Perkinson
Re: data labels?
You can select the points you want labeled and choose Rows -> Label/Unlabel.
Another option in JMP 11 and beyond is to hover over the point until the label appears. Then move the pointer into the label and you can pin it in place.
To choose the column(s) used for the labels select the column(s) and choose Cols -> Label/Unlabel.
-Jeff
-Jeff
Kevin_Anderson
Re: data labels?
JMP Help is remarkably helpful.  I recommend following the instructions on page 158 of the Using JMP book (in JMPv11) that is installed with the package.  You can find it under Help -> Books -> Using JMP.
jfendrich
Re: data labels?
Thanks. Strongly agree p.158 of Using JMP 11.1 2nd ed. is very useful, in particular for my analysis, the adding labels for only particular rows / data of interest, the section highlighted below was the exact instructions I needed. Thanks again!
Jeff_Perkinson
Re: data labels?
-Jeff
-Jeff
jfendrich
Re: data labels?
Thanks. Very helpful, worked for me. See my response to Kevin's advise as well.
