Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
KinKame
creation of link
Hello
I would like to know if it would be possible getting link information and a title to create a new link based on those 2 information
Header 1Header 2Header 3
Link (http// ....)NAMENAME
8 REPLIES 8
Re: creation of link
Is your question:
If I have a URL link in a column in a data table, and a title in another column in a data table, can I put that information together to come up with a new URL link in a third column?
If that is the question, the answer is yes, but I am not sure that is what you are asking.  Can you please provide more specifics on what you are asking?
KinKame
more specific
I have a table with
column 1 --> link (for example: https://community.jmp.com/)
column 2 --> name (for example JMP)
I would like to create column 3 as
column 3 --> JMP (similar to HYPERLINK function in excel)
reason is sometimes http are very long and not usable for viewing.
If not possible I can go thru excel no issue but would prefer to have all in JMP
pmroz
This will do it:
// Assumes that you have a column called Header 3 with a description of what to get
// and another column called Header 1 with the actual URL
dt << new column("Select Logic", character,
    formula(
        dst = current data table();    // Need a local variable because this is a formula
        If (Selected(),
            sel_cols = dst << get selected columns;
            sel_rows = dst << get selected rows;
            if (islist(sel_cols),
// then
if (nitems(sel_cols) == 1 & nrows(sel_rows) == 1 &
uppercase(char(sel_cols[1])) == "Header 3",
// then
my_url = column(dst, "Header 1")[sel_rows[1]];
web(my_url);    // Does the actual work
);    // end 1 col, 1 row, AER col
            );    // end islist
        );        // end if selected
        "x";    // Need a dummy value for the column
    );    // end forumula
);    // end new column
column(dt, "Select Logic") << hide;
KinKame
ok got it. thank you very much
I did not know this web function but seems pretty cool.
KinKame
Ok PMorz,
it doesnt really work.
I can actually create a logic column filled with "x"...
any hint?
pmroz
Sorry - didn't test my logic.  This code will work:
dt = New Table( "Example Web Logic", Add Rows( 3 ),
    New Column( "Click for Web", Character, "Nominal",
        Set Values( {"JMP", "Google", "JMP Community"} )
    New Column( "Link", Character, "Nominal", Hide,
        Set Values(
            {"http://www.jmp.com", "http://www.google.com",
            "https://community.jmp.com/community/discussions"}
    formula(
        If (Selected(),
            // then
                    (sel_cols[1] << get name) == "Click for Web",
                // then
                    my_url = column(dst, "Link")[sel_rows[1]];
            );    // end islist
    ); // end forumula
ian_jmp
Building on Peter's thoughts, you could also use the 'row state handler':
New Column( "Link",
Character,
"Nominal",
Value Labels(
{"http://www.google.com" = "Google", "http://www.jmp.com" = "JMP",
"https://community.jmp.com/community/discussions" = "Community"}
Use Value Labels( 1 ),
Set Values(
// Follow the link in each row currently selected
followLinks =
Function({x},
ForEachRow(
If( Selected( Row State()), Web(Column(dt, "Link")[Row()]) );
// Assign the handler to the table
rsh = dt << MakeRowStateHandler(followLinks);
(In passing, I note that an expression column does not seem to allow the use of value labels).
pmroz
A row state handler is a good idea.  I think I developed my approach before that came available.  It's a cleaner solution.
Article Labels
