completely randomized block design: How to include the blocks in JMP?
Let's say I got an experimental wheat field where I want to investigate how different treatments influence my YIELD. The treatments are:
1) PLOUGH
A: ploughing at 20cm
B: ploughing at 40cm
C: no ploughing
2) FERTILIZATION
1: 100 Kg/ha
0: no fertilization
Unfortunately my field is inclined, therefore I need to add blocks (I, II, III)
Block IA1B1C1A0B0C0
Block IIB1A0A1B0C0C1
Block IIIC1B0C0A1A0B1
If I go to "Fit Model" and put my YELD as Y and use MACRO -> Fullfactorial with PLOUGH and FERTILIZATION I think I can get results just as a completely randomised design. So my question is: How to include the blocks in Fit Model?
Maybe I should use "Fit Y by X" (there is the block option). But then how to include the full-factorial?
Thank you,
Matteo
louv
Staff (Retired)
Re: completely randomized block design: How to include the blocks in JMP?
I would recommend using Custom Design.
I quickly just chose one three level categorical for Plough, one two-level categorical for Fertilizer and then chose block of size 6
12698_Screen Shot 2016-09-09 at 3.45.24 PM.png12698_Screen Shot 2016-09-09 at 3.45.24 PM.png
12699_Screen Shot 2016-09-09 at 3.47.09 PM.png12699_Screen Shot 2016-09-09 at 3.47.09 PM.png
Simulating that experiment gives this output. (I had to reset factor grid to show the block in the Prediction Profiler.
12700_Screen Shot 2016-09-09 at 3.50.25 PM.png12700_Screen Shot 2016-09-09 at 3.50.25 PM.png
Hope this helps,
PS Perhaps you might want to investigate utilizing a Split-plot design
Lou
louv
Staff (Retired)
Hope this helps,
Lou
Thank you very much Lou. That's just an excellent explantation.
And what if I want to use repeated measure ove time within the same experiment? For example if I want to monitor CO2 efflux every month? Does somedoby have some idea?
