mpatpc
creating a mean table with p-vaue
Looking to create a data output table from an comparison of means analysis that shows the mean of each atrribute by sample with p-value to show if the mean values are significantly different. How can I do that in JMP? I can generate a table using tabulate but cant seem to add p-value which is generated during hte one way anova analysis
10 REPLIES 10
Kevin_Anderson
Re: creating a mean table with p-vaue
Perhaps I'm overly-sensitive, but since this sounds a bit like p-hacking to me, I thought it might help to post the American Statistical Association position paper on the proper use of p-values.
