See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
creating a map of cell by cell value
Boaz
Hi JMPers,
I'm trying to create a plot of column Z by a matrix of X & Y, (X & Y have discrete values, Z is continues).
was only able to create contour plots but I'm trying to get something like this:
does anyone have an Idea?
would love a solution in  a script format....
mzwald
Re: creating a map of cell by cell value
Hi Boaz,
What you are showing would be accomplished with the Heatmap option from Graph Builder.  Please refer to this script for an example:
dt = Open( "$SAMPLE_DATA/Wafer Stacked.jmp" );
dt:X_Die << Set Modeling Type( "Ordinal" );
dt:Y_Die << Set Modeling Type( "Ordinal" );
dt << Graph Builder(
	Size( 554, 521 ),
	Variables( X( :X_Die ), Y( :Y_Die ), Color( :Defects ) ),
	Elements( Heatmap( X, Y, Legend( 4 ) ) )
I suggest that you create a shape map of your x and y matrix, and then use Graph Builder to generate the choropleth map.
See the Maps section in the Essential Graphics document in the JMP Documentation Library under the Help pull down menu
ian_jmp
Level X
Building on the reply from @txnelson, please find attached some (now rather old) code that might get you started. It probably does more (and perhaps less . . . ) than you need. Use 'Help > Scripting Guide' and other documentation to figure out how it works.
mzwald
Hi Boaz,
	Size( 554, 521 ),
Boaz
Thanks,
Got exactly what I wanted!
