dwaterson
counting rows based on values in another column
I have a column that defines a grouping, like a column called 'gender' that contains the values 'male' and 'female'. I want to know how many rows in the dataset = 'male' and how many rows in the dataset = 'female'.
vince_faller
Re: counting rows based on values in another column
dt = current data table();
dt << Select Where(:Gender == "male");
male = nrows(dt << Get Selected rows());
dt << Select Where(:Gender == "female");
female = nrows(dt << Get Selected rows());
Vince Faller - Predictum
pmroz
You can use Tables > Summary.  Here's a JSL version:
dt = open("$sample_data/Big Class.jmp");
dt << Summary( Group( :sex ), N );
There's also the SUMMARIZE command in JSL.  You need a numeric column to get this to work though:
summarize(gsex = by(:sex), gcount = count(:height));
print(gcount);
[18, 22]
vince_faller
pmroz
print(gcount);
[18, 22]
dwaterson
Thank you for these responses. Is there any way to do this within a column formula?
ms
Super User (Alumni) ms
Col Number(Row(), :Gender)
Thanks! This helped me out.
