Ohad_s
computer recommendations
I need a new pc to handle my jmp analysis. the PC will be used only for jmp.
most of my data is > 150M rows.
my raw data is multiple csv files with an overall size of > 50giga.
my current computer with 16 giga RAM and i12 process is not handling this amount of data.
I like to get suggestions from people here about the hardware I need.
thanks
Re: computer recommendations
My personal thoughts, others will have additional great input
CPU:  JMP Platforms use multiple threads for processing, so I suggest as fast a processor with as many cores and threads as you can afford.
RAM: JMP tables are required to be in memory for processing so I suggest 64gig of RAM
HardDrive(Disk Storage):  At least a terabyte M.2 solid state drive
GPU:  Not a lot of complex rendering or video in JMP, so get a good Graphics card, but  a high end card is not required.
Monitor(s):  At least dual monitors at 1080x1920 or more.
Just knowing the row count doesn't really mean anything as the tables could just contain single column with all values being same integer (column count and data structures do matter (integer vs float, character vs numeric and so on...). You could also contact JMP Support through email, they will most likely be able to provide you more accurate recommendation. They also know which extra questions to ask so they can come up with the best possible suggestion.
My only suggestion is to have as fast as possible memory and as much of it as possible.
lala
Level IX
回复: computer recommendations
It is recommended that you first extract the CSV using "EmEditor" segmentation into JMP.
Ohad_s
you are correct.
my tables are between around 12 columns, most of them are continuous numeric data (float), 1 or 2 are character
