The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
View Original Published Thread
computer name
pniel
Hi jmpers,
I need to build an application in jmp for different users, meaning that different users will have different User Interface.. (it is the same application) I was wondering if is there a way to get user profile? Let say computer name, user name or server name from jmp ? Doing so I can decide which script to open
Tanks
pniel
18 REPLIES 18
mattf
Level V
Re: computer name
Hi:
Assuming Windows XP and JMP 8 one can retrive Windoz variables via the LoadDLL command - (also with JMP 9 if one wants to retrieve all of the ENV variables).
Example below uses the "GetEnvironmentStrings" windows function to retrive all the global environmental variables (including COMPUTERNAME) and for fun loads then in a data table and an array.
see:
http://www.nesug.org/Proceedings/nesug10/ad/ad04.pdf
Best regards,
-Matt
pmroz
Re: computer name
Can someone help me with the syntax for calling a DLL?  I want to get the user's username using the Windows API GetUserName function.  I don't want to look up the username environment variable because that can be spoofed.
Advapi32.dll
BOOL WINAPI GetUserName(
  _Out_    LPTSTR lpBuffer,
  _Inout_  LPDWORD lpnSize
Thanks!
JohnPonte
Staff (Retired)
Re: computer name
Here is some JSL that I wrote for getting the username from the system. This worked in JMP 10, running on Windows 7.
dll = Load DLL( "mpr.dll" );
dll << DeclareFunction(
     "WNetGetUserA",
      Convention( STDCALL ),
      Alias ( "GetUserName" ),
      Arg( UInt8, "format", input ),
      Arg( AnsiString, "username", output ),
      Arg( UInt64, "length", update ),
      Returns( UInt32 )
username = "                                                  ";
unlen = length(username);
result = dll << GetUserName(0, username, unlen);
show(username);
dll << UnloadDLL();
First, you need to load the system DLL. I didn't have any luck with Advapi32.dll. But I found what I needed with mpr.dll. Notice I didn't need to specify a path to the DLL since it was on my system path.
dll = Load DLL("mpr.dll");
Next, you need to declare any method that you are going to call in the DLL. The method I want to use is actually called WNetGetUserA(), but by defining an alias, I can simply call it using GetUserName().
      "WNetGetUserA",
      Returns( UInt32 )
Now I want to define the variables that I am going to pass in as arguments. I create a username and initialize it to blanks. Then I use the length() function in JMP to get the current length of the buffer I just created.
username = "                                                  " ;
Now I can call the function. Notice the first argument is input only, so I just use a constant instead of defining a variable. Then the show() command shows my username after making the call.
show(username);
Finally, I am done so I clean up.
dll << UnloadDLL();
I hope this works for you. If you come up with a better way, please let us know.
By the way, using loadDLL only works on Windows. It isn't supported on the Mac. For that reason I do a check at the top of my script.
If( Host is( Mac ),
     Print( "Sorry, this script is not supported on Mac." );
     Stop();
Enjoy,
JohnP
pmroz
Re: computer name
JohnP,
Thanks so much!  That's exactly what I'm looking for.  Can't mark this as the correct answer because I didn't start this thread.
JohnPonte
Staff (Retired)
Re: computer name
The original post also asked about the computer name. To get the computer name, use Kernel32.dll and the method name, GetComputerNameA(). So it will look like this:
dll = Load DLL( "Kernel32.dll" );
     "GetComputerNameA",
      Alias ( "GetComputerName" ),
      Arg( AnsiString, "computername", output ),
      Returns( UInt32 )
name = "                                                  ";
unlen = length(name);
result = dll << GetComputerName(name, unlen);
show(name);
dll << UnloadDLL();
JohnP
mattflynn
Re: computer name
JMP 10 supports this query directly
Get Enviromental Variable("Computername")
Best,
-Matt
pmroz
Re: computer name
I need something that can't be hacked by something as simple as setting the environment variable.  Thanks JohnP for both solutions!
jmpbeginner
Re: computer name
thanks, syntax in JMP12 is actually:
Get Environment Variable("Computername");
Byron_JMP
Re: computer name
For Mac OS
Try this:
If( Host is( "Mac" ),username=Get Environment Variable( "USER" );
	stamp="Test "||username||", "||char(today());
