JohnPonte
Re: computer name
Here is some JSL that I wrote for getting the username from the system. This worked in JMP 10, running on Windows 7.
dll = Load DLL( "mpr.dll" );
dll << DeclareFunction(
     "WNetGetUserA",
      Convention( STDCALL ),
      Alias ( "GetUserName" ),
      Arg( UInt8, "format", input ),
      Arg( AnsiString, "username", output ),
      Arg( UInt64, "length", update ),
      Returns( UInt32 )
username = "                                                  ";
unlen = length(username);
result = dll << GetUserName(0, username, unlen);
show(username);
dll << UnloadDLL();
First, you need to load the system DLL. I didn't have any luck with Advapi32.dll. But I found what I needed with mpr.dll. Notice I didn't need to specify a path to the DLL since it was on my system path.
dll = Load DLL("mpr.dll");
Next, you need to declare any method that you are going to call in the DLL. The method I want to use is actually called WNetGetUserA(), but by defining an alias, I can simply call it using GetUserName().
      "WNetGetUserA",
      Returns( UInt32 )
Now I want to define the variables that I am going to pass in as arguments. I create a username and initialize it to blanks. Then I use the length() function in JMP to get the current length of the buffer I just created.
username = "                                                  " ;
Now I can call the function. Notice the first argument is input only, so I just use a constant instead of defining a variable. Then the show() command shows my username after making the call.
show(username);
Finally, I am done so I clean up.
dll << UnloadDLL();
I hope this works for you. If you come up with a better way, please let us know.
By the way, using loadDLL only works on Windows. It isn't supported on the Mac. For that reason I do a check at the top of my script.
If( Host is( Mac ),
     Print( "Sorry, this script is not supported on Mac." );
     Stop();
Enjoy,
JohnP
pmroz
Re: computer name
JohnP,
Thanks so much!  That's exactly what I'm looking for.  Can't mark this as the correct answer because I didn't start this thread.
JohnPonte
Re: computer name
The original post also asked about the computer name. To get the computer name, use Kernel32.dll and the method name, GetComputerNameA(). So it will look like this:
dll = Load DLL( "Kernel32.dll" );
     "GetComputerNameA",
      Alias ( "GetComputerName" ),
      Arg( AnsiString, "computername", output ),
      Returns( UInt32 )
name = "                                                  ";
unlen = length(name);
result = dll << GetComputerName(name, unlen);
show(name);
dll << UnloadDLL();
JohnP
mattflynn
Re: computer name
JMP 10 supports this query directly
Get Enviromental Variable("Computername")
Best,
-Matt
pmroz
Re: computer name
I need something that can't be hacked by something as simple as setting the environment variable.  Thanks JohnP for both solutions!
jmpbeginner
Re: computer name
thanks, syntax in JMP12 is actually:
Get Environment Variable("Computername");
Byron_JMP
Re: computer name
For Mac OS
Try this:
If( Host is( "Mac" ),username=Get Environment Variable( "USER" );
	stamp="Test "||username||", "||char(today());
JMP Systems Engineer, Pharm and BioPharm Sciences
