maryam_nourmand
best model
Hello
my question is how can i find best parametric model that fits very well on my dataset?
i want find a parametric model that can predict good my response
12 REPLIES 12
maryam_nourmand
Re: best model
Yes, by "parametric model" I do not mean machine learning models.
My goal in finding the best parametric model is to simulate and generate data with a larger quantity than my initial dataset. I want to use more data for my machine learning model, but I want the simulated data to closely resemble and be similar to my initial dataset.
dlehman1
Level V
Re: best model
I don't see why you need a parametric model to do that.  You can run any predictive model and use the Profiler to simulate any number of additional data points, specifying different values for the independent variables and adding random noise to the predictions.  Perhaps I am not understanding what you intend to do, but I don't see the parametric model part of this as necessary.
maryam_nourmand
Re: best model
What is the difference between saving simulation formulas through "Save Columns -> Save Simulation Formula" and simulating using the Profiler tool?
The reason I am using a parametric model for simulation is that I want to have the relationship and the simulation formula so that I can write the corresponding code and repeat this process 100 times in a loop (to obtain the ARL of my control chart based on the model I constructed in phase I ).
If I were to do this manually with the software, it would be time-consuming and difficult.
