viskovicz00012
append in ppt
Help- - how to append my for loop of producing of correlation plots from which each slide contains 4 plots?
For( i = 1, i <= N Items( new_b ), i++,
				Bivariate(
					Y( Column( cor_tab, new_b[i] ) ),
					X( Column( cor_tab, ref_b[i] ) )));
Re: append in ppt
JMP saving to PowerPoint will copy each individual graph to a separate slide.  Therefore, the below script groups the graphs into 2x2 groupings as a separate Picture object, and then saves those to PowerPoint.
Names default to here(1);
cor_tab=open("$SAMPLE_DATA/semiconductor capability.jmp");
new_b = cor_tab << get column names(string, continuous);
remove from(new_b,1,1);
ref_b = cor_tab << get column names(string, continuous);
// Create a Journal to temporally hold the graphs
nwj = new window("Graphs", <<journal);
// Loop across the columns specified in the new_b list
	// If this is the first of 4 graphs, create an object
	// to hold the graphs.  In this case, a linup box that
	// has 2 columns.  Four graphs, when passed to it will
	// be placed into a 2 column by 2 row display
	If( Mod( i, 4 ) == 1,
		fourby = Lineup Box( N Col( 2 ) )
	// Run the Bivariate
	biv = Bivariate( Y( Column( cor_tab, new_b[i] ) ), X( Column( cor_tab, ref_b[i] ) ) );
	// Take the output from the bivariate and place it in the outline box
	fourby << append( Report( biv )[Outline Box( 1 )] );
	// Close the no longer needed Bivariate report
	biv << close window;
	// If 4 graphs have been run or if this is the last graph,
	// it is time to move the outline box to the journal.
	// If the outline box was copied directly to the journal,
	// it would be copied as a 2x2, but there would be 4 separate
	// graphs, and when the journal is saved to PowerPoint, JMP
	// would save each graph to a separate slide.  Therefore, the
	// 2x2 is converted to a single picture as it is moved to
	// the journal.
	If( Mod( i, 4 ) == 0 | i == N Items( new_b ),
		nwj << append( fourby << get picture )
// Save the journal as a PowerPoint
nwj << Save Presentation("$TEMP\the fourby charts.pptx");
// Close the no longer needed journal
nwj << close window;
// Display the PowerPoint slides
open("$TEMP\the fourby charts.pptx");
Re: append in ppt
	// the journal.
