rcmjh
allocate rows for specific test samples in a validation column
When using linear discrimination I want to determine groups for unknowns. I assume I can do this by making the unknowns a validation or test set but this seems to be allocated randomly. How do I specify specific rows as a validation/test set?
Re: allocate rows for specific test samples in a validation column
Hi @rcmjh,
You can create a validation column manually and use Value Labels (see screenshot below) in the Column Info to let JMP know which rows are your validation (or even test) sets.
Thanks,
Ben
rcmjh
thanks, very helpful
