adding a table on the firts tab of a dashboard
Can i add in the first tab a table ?  like the example.
// Create a table for the first tab
tableBox = dt << Summary(
    Group( :sex ),
    Mean( :weight ),
    Mean( :height ),
    N
gb_collector = Tab Box( "Dashboard",
    V List Box(
        tableBox
For( i = 1, i <= 20, i++,
    // Column box for plot of all batches
    col1 = Col Box( "All Batches" || Char( i ) );
    // Create the first Graph Builder plot
    gb = Expr(
        dt << Graph Builder(
            invisible,
            Variables( X( :weight ), Y( :height ), Overlay( :sex ) ),
            Elements( Points( X, Y, Legend( 9 ) ), Line Of Fit( X, Y, Legend( 11 ) ) )
    col1 << Append( gb );
    // Create column boxes for the Graph Builder plots
    col2 = Col Box( "Actual Data " || Char( i ) );
    col3 = Col Box( "Actual  " || Char( i ) );
    // Loop to create and append multiple Graph Builder plots to col2 and col3
    For( j = 1, j <= 2, j++,
        gbb = Expr(
                invisible,
                Elements( Points( X, Y, Legend( 5 ) ), Line Of Fit( X, Y, Legend( 11 ) ) )
        col2 << Append( gbb );
        gbbb = Expr(
                invisible,
        col3 << Append( gbbb );
    // Create a tab for col1, col2, and col3 and append it to gb_collector
    tab = Tab Page Box( Char(i),
        V List Box(
            col1,
            H List Box( col2, col3 ) // Placing the two plots next to each other
    gb_collector << Append( tab );
gb_collector << Dockable( 1 );
gb_collector << Set Overflow Enabled( 1 );
nw = New Window( "Dashboard",
    gb_collector
Re: adding a table on the firts tab of a dashboard
You can for example use get as report
New Window("Example",
	tb = Tab Box(
		Tab Page Box("First Tab", Tip("First Tab Tooltip"), Button Box("Press One")),
		Tab Page Box("Second Tab", Closeable(1), Button Box("Press Two")),
		Tab Page Box("Third Tab", Icon("Nominal"), Button Box("Press Three"))
Wait(1);
dt = open("$SAMPLE_DATA/Big Class.jmp");
tb << Insert(1, Tab Page Box(Title("To first"),
	dt << get as report
You can use Insert with Tab Box to determine into which position display box should be added
With index
	tb = Tab Box(
Wait(1);
tb << Insert(1, Tab Page Box(Title("To first"), Button Box("Press Four")));
thank you ! but the thing is that i am straggling printing the table on a tab.
gb_collector = Tab Box();
    gb = Expr(
            invisible,
        gbb = Expr(
                invisible,
        gbbb = Expr(
                invisible,
        V List Box(
            col1,
tableBox = Expr(dt << Summary(
    Group( :sex ),
    Mean( :weight ),
    Mean( :height ),
    N
// Create the "Results" tab
resultsTab = Tab Page Box("Results", tableBox);
// Insert the "Results" tab at the first position
gb_collector << Insert(1, resultsTab);
    gb_collector
	tb = Tab Box(
Wait(1);
	dt << get as report
