Hello -
When using the Xbar Control Chart function, I've found that despite using a Column to identify the Subgroups, the data table must also be sorted by the Subgroup Column to properly chart the data. Further, despite having a Value Order Column Property on the Subgroup Column, the x-axis is still ordered by Row of the Table.
I understand showing data in Row order is appropriate to a Run Chart, however, for Xbar Control Charts, x-axis ordering should be dictated by the Subgroup.
Is there a way to override this forced-ordering? Can it be modified in future editions of JMP?
Thanks-KL
