JMP 18 unable to register
Hi there,
Ive been trying to study for my test on JMP 18 and every time I try to open the software, I keep getting JMP 19 when my studies have to do only with JMP 18.
1. How can I make it possible to use JMP 18 and not the latest version
2. Would I need to cancel my account first (JMP 19) or is it a setting problem which takes a few clicks.
Thank you
Re: JMP 18 unable to register
Are you using student license? My guess is that it would require latest the JMP version but I'm not sure. If it doesn't you would have to find find installer for JMP18 as my.jmp.com will only offer the latest one.
bobmorrane
Level V
I also have the same issue. This new authentication thing is super annoying!!!
~~Bob~~
