import JMP config from previous version when upgrading
May 4, 2026 10:49 AM(709 views)
Hi, I just lost half a day of work because the Autosave timer I had set in JMP18 was set to the default of 0 in JMP 19. Can the installer not just search (or ask the user) for the previous JMP installation config?
It generally does but going to JMP19 most of the preferences are not auto-imported (not sure if any are). My guess is that there are changes to the preference structure and using previous configuration could cause issues.
