MRB3855
With missing data, Fit Model platform doesn't run properly across all "by" variables
Good day: I just noticed this phenomena in v17.  See attached data file to show what I will try to describe.  In the attached, there are three responses, Y1, Y2, Y3.  There is a categorical factor and a by variable.  But, Y1 and Y2 are  missing for some of the By variables.  If I run the Fit Model platform with Y1, Y2, and Y3 as responses, "Cat" as a factor, and the "By Variable" as the By variable, the results are surprising. I get no results for By Variable A, only Y1 results for By variable B, Then all (Y1, Y2, Y3) results for C, D, and E. And it's not a "fit separately" issue either.  If I run the Distribution platform, however, choosing Y1, Y2, and Y3 as responses and "By Variable" as the By variable, it works as I'd expect. And this phenomena not happening in the Variability/Attribute Gauge Chart either. I don't recall this issue in v16. Help anyone?
11 REPLIES 11
AnjaW
Re: With missing data, Fit Model platform doesn't run properly across all "by" variables
Hi @MRB3855 ,
thanks for your reply.
As you can see in the screenshot below: if I choose "Generalized Regression" only an error message pops up. If I click "OK" nothing else happens. No window opens.
MRB3855
Hi @AnjaW : It appears the issue I identified is not completely corrected (and I was able to replicate your issue with v18). I suggest you contact JMP support ([email protected]), and when you do you may want to provide a link to this thread as well.
