Why the lambda value of Spline fitting used in "Fit Y by X analysis" is different from the "Graph Builder"?
Created:
Sep 16, 2021 09:35 PM
| Last Modified: Jun 11, 2023 4:17 AM(6566 views)
Hello, JMP developers,
I'm using JMP15.2.1 version.
As below smooth fitting results(same datasets) in JMP when using the One Way Analysis (Fit Y by X) platform vs. Graph Builder, by setting the same lambda=100, the smoothness of the curve is totally different. (Fits are the same even if the lambda values differ by approximately 20x)
The graph builder uses standardized X variables. To get the same line in Bivariate, choose 'Other...' under the Red Triangle > Flexible > Fit Spline, use a lamda of 0.05 (default in graph builder) and check 'Standardize X'.
Standardized X means that you normalize your X distribution:
x = [[[ ARRAY OF X VALUES ]]]
x = (x - Mean( x )) / Std Dev( x );
After this, you'll create your cubic smoothing spline polynomials, then when creating your splines (which will be placed into this new scaled-x space), you simply unscale your spline's x-values.
I have a bit more data that I used and I get a very different spline fit using the graph builder and bivariate spline fit. The graphs have the same scales, and there seems to be a horizontal shift in the splines.
The graph builder is on top while the bottom is from the bivariate fit.
TIA for any input
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '418865' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '418865') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '418865') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
