mattpace0
Where did the variability chart toolbar item go and how to get it back please?
JMP 14, the variability chart button is gone from the analyze toolbar. (why do you have to change things)   How to get it back please?
I have tried cutomize toolbars, but there are no option to add anything, just empty
10 REPLIES 10
cwillden
Re: Where did the variability chart toolbar item go and how to get it back please?
Analyze > Quality and Process > Variability / Attribute Gauge Chart
-- Cameron Willden
mattpace0
I'm sorry, the button is gone from the toolbar.  It used to take one click, not it takes 3
Please go to the JMP Wish List, and specify your opinion to change it back to the old structure.
And also, you can go to
View==>Customize==>Menus and Toolbars
and then go down to the place where the Variability/Attribute Chart is located, copy the entry, and the go back to the location on the Analyze menu, and insert it into the Analyze main menu. And you will be right back to where you were in JMP 13
mattpace0
Thank you for being willing to help.
Am I missing something please?
I can't even figure out how to get it back the way it was.
The customizing Menus and Toolbars is fully documented in the "Using JMP" book
     Help==>Books==>Using JMP
You can always go to
     File==>Preferences
and click on "Reset to Defaults" to go back to factory defaults
Here is an image of the JMP Menu Editor where I added a button for calling the Variability Chart platform.  Instructions for adding a toolbar button can be found in the Personalize Toolbars and Menus on Windows section of Using JMP (Help > Books > Using JMP).
Hope that helps!
Wendy
mattpace0
Thank you, I was able to do it.  But, that is painful,
Hope that helps!
Hi @Wendy_Murphrey, Your screenshot was super helpful! I didn't even need to go the to help files (books), just replicated what you did here. Thanks for including the image with the annotations. Cheers, @PatrickGiuliano
Wen
Wen
  1. Insert before or after (Figure Step 1)
  2. Type to Insert: command
  3. Select ANALYZE: QUALITY AND PROCESS: VARIABILITY (Figure Step 2)
  4. Save
