  • JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, December 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
    Regular business hours will resume at 9:00 a.m. EST on Friday, January 2, 2026.
lala
Level IX
When drawing bubbles, how can I set the background color to different colors according to the number of rows?
Hello!
For example, set lines 1-20 and 21-40 to different background colors.
dt=Open("$SAMPLE_DATA/Big Class.jmp");
p1=dt<<Bubble Plot(
	X( Transform Column( "Row", Formula( Row() ) ) ),
	Y( :height ),
	Sizes( :weight ),
	Coloring( :sex ),
	Title Position( 0, 0 ),
		Dispatch(
			"1",
			ScaleBox,
			{Min( 0 ), Max( 45 ), Inc( 5 ), Minor Ticks( 0 )}
		Dispatch(
			"2",
			ScaleBox,
			{Min( 50 ), Max( 72.5 ), Inc( 5 ), Minor Ticks( 1 )}
		Dispatch(
			"Bubble Plot",
			FrameBox,
			{Frame Size( 565, 360 ), Background Color( 76 )}
回复: When drawing bubbles, how can I set the background color to different colors according to the number of rows?
You could use reference lines with allow range enabled
bp = dt << Bubble Plot(
	X(Transform Column("Row", Formula(Row()))),
	Y(:height),
	Sizes(:weight),
	Coloring(:sex),
	Title Position(0, 0)
wait(1);
axisbox = Report(bp)[axis box(2)];
axisbox << Add Ref Line({0, 20}, "Solid", "Red", "", 1, 0.25);
axisbox << Add Ref Line({20, 40}, "Solid", "Medium Light Blue", "", 1, 0.25);
Or then graphic scripts but I think reference lines with range are easier in this case.
lala
Level IX
Not work.
Fill Color("blue"); Rect( 1, 80 , 20 ,50,  1);,
	Y(:height),
	Sizes(:weight),
	Coloring(:sex),
wait(1);
lala
Level IX
Thank you for your help!
bp = dt <<Graph Builder(
	Size( 532, 453 ),
	Variables(
		Y( :height ),
		Color( :sex ),
		Size( :height )
	Elements( Points( X, Y, Legend( 17 ) ) )
axisbox = Report(bp)[axis box(1)];
