Level XII
What's wrong here? Expression issue in Formula()
Caution - JMP will crash!!!
f = Function( {},
	ID = Associative Array( {{Name Expr(), 1}, {Expr(), 2}, {Function(), 3}}, 0 );
/* .... */ ); f();
removing the function() from the list fixes the error.
Taking the associative array out of the outer function fixes the error.
[edit] a motivation why this can be helpful:
as a lookup table for parts of expressions - identified via Head()and Type():
myID = ID[Expr(function())]; //  expected: 3
code = Expr(g = function ({x},1));
Head(Arg(code,2)); // function()
myID = ID[Head(Arg(code,2))]; // expected: 3
8 REPLIES 8
Re: What's wrong here?
It sure does blow JMP away.  You just invented a new fast way to exit from a JMP session......
This needs to go to JMP Support!   Things like this are not supposed to happen.
Level XII
I have another one:
x = Expr(Function());
Show(name Expr(x) == Expr(Function()));
Print("not dead");
f = function({arg},
name Expr(arg) == Expr(Function()))
outside of the function the comparison of x with Function () is OK.
Inside of the function, JMP will already crash when it sees the command - no need to call f.
Level XII
from JMP support (TS- 00166834):
There is a known issue where JMP crashes when using a malformed function in another function.
So, the root cause can be narrowed down to
f = Function( {}, 	Expr(Function()));
... looking so innocent.
malformed
 function definition - yes. But it's a "well formed" JSL expression  according to
@joseph_morgan /  Using JSL to Develop Efficient, Robust Applications (EU 2018 415) .
So, surprising that JMP cannot live with it.
Function inside Function reminds me of JMP Expr() weirdness, can anyone explain? / @ErraticAttack .
So, besides the users, even JMP has issues when an expression shows up on different levels. So, maybe Insert Into: Flatten(0|1)  or @Substitute First Occurence  could even help JMP?
The suggestions from JMP support:
There are a couple of other things you can do to prevent the crash.  One is to put the curly braces ({}) as a required argument in the internal function. Another is to remove the parentheses after the word Function in the internal function.
unfortunately no help for the application case from above.
Level XII
A workaround :
f = Function( {},
	ID = Associative Array( {{"Name Expr()", 1}, {"Expr()", 2}, {"Function()", 3}}, 0 );
f();
myID=ID[Char(Head(Arg(code,2)))]
but it "hurts" a bit ...
Level XII
I like this one a lot more:
f = Function( {},
	Eval (Eval Expr(ID = Associative Array( {{Name Expr(), 1}, {Expr(Parse("Expr()")), 2}, {Expr(Parse("Function()")), 3}}, 0 )));
f;
myID=ID[Head(Arg(code,2))];
It can't work, after the eval expr it will be more or less the same as before ...
... wow!
NB: Expr()won't survive the Eval Expr - so has to get protected.
Level XII
bculver
Re: What's wrong here? Expression issue in Formula()
I actually just submitted this bug report a few days ago! I found that using Expr(Function()) inside a function causes a crash. I was using it in the context of
Substitute(my_expr, Expr(Function()), Expr(Method()))
But was able to get by using Expr(Function) instead.
For your issue, another possible solution if you don't want to parse strings is do something like this
y = Function({head_key},
	ID = Associative Array( EvalList({{Name Expr(), 1}, {Expr(), 2}, EvalList({Head(Expr(Function({},1))), 3})}), 0 );
    ID[NameExpr(head_key)]
Show(y(Expr(Function())));
Although still not exactly 'pretty.'
Level XII
Head(Expr(Function()))
nice!
much better than my Eval( ... Parse(  ...   especially after citing Joseph's
