Marco1
What is the difference between noise factor and Simulation experiment?
Hello everyone!
A Query: What is the difference between noise factor and Simulation experiment?
Regards!!
Marco
MRB3855
Re: What is the difference between noise factor and Simulation experiment?
Hi Marco: I do not understand your question. Can you please provide some context and a more detailed/clear question?
Regards, Mark
Marco1
Hi MRB3855, I am pleased to greet you, the following is not clear to me:
1. How does "Noise factors"... "How does the profiler located in the graphics menu arrive at the answer"?
2. How does "Simulation Experiment" ... "how do you get to the answer" the prediction profiler?
3. Noise factors and Simulation experiment find the optimal value of the uncontrollable variable?
Regards,
Marco
Hi Marco,
Can you please provide even more context? Such as: which platform are you using; what step of your analysis, etc.
Thanks!
