UserID16644
Level V
Run functions when column is not empty
Hi all,
I have a function where I needed it running when and only the column is not blank. How can I properly check if the column is not blank and run the function, I tried isMissing() but is not working properly.
Sample function:
exsqr = Function( {x}, x * x );
exsqr( 5 );
So it would look like something like this:
exsqr0; //function1
if (isMissing(Column1),  //if Column1 has values, it should run the function, else, skip this function and proceed to function3
exsqr); //function2
exsqr1; //function3
Re: Run functions when column is not empty
You could use Col N Missing in combination with N Rows or Col Number to check if there are anything else besides missing values. Below are some ideas:
dt = New Table("Untitled",
	Add Rows(3),
	New Column("Column 1", Numeric, "Continuous", Format("Best", 12), Set Values([., ., .])),
	New Column("Column 2", Numeric, "Continuous", Format("Best", 12), Set Values([1, ., 3]))
Show(Col N Missing(:Column 1));
Show(Col N Missing(:Column 2));
If(N Rows(dt) - Col N Missing(:Column 1) > 0,
	Show(:Column 1 << get values);
Show(Col Number(:Column 1));
Show(Col Number(:Column 2));
If(Col Number(:Column 2) >= 0,
	Show(:Column 2 << get values);
