Level XIII
What is not possible via JSL?
https://community.jmp.com/t5/Discussions/Is-it-possible-to-show-excluded-row-values-on-chart-via-JSL...
Where are the limits?
I mean:
- where is the the GUI/mouse user ahead of his JSL colleague?
- where is a hard wall for any Jmp user?
11 REPLIES 11
Level XIII
Re: What is not possible via JSL?
#2: it is not possible to create a custom function with a column reference *)
(Jmp v17.2)
*) one  which could be used in the right click new formula column menu:
Custom Function - how to reference the column
actually, a similar question was asked some while ago by @jthi  together with some other questions:
Creating statistical custom (formula) function which has byVar and  @ih shows that with some workaround it's possible to solve the first riddle: create a custom function with a column reference
But the workaround prevents it from being usable in the right click new formula column menu :(
edit:
same question some years ago:
Column reference in custom function
WebDesignesCrow
This is a good idea. Rather than fixed the name as control limit. Just name it with "Customized Limits". Sometimes user may want to add alarm before control limits.
Thanks for sharing. I will upvote the above wishlist first
