jeff_kolton1
What does ill-conditioned regression problem alert mean?
I'm  using Fit Model > Standard Least Squares, Effect Screening using Macros > Factor to Degree (2). and get the following alert:
Any help to understand and resolve would be greatly appreciated.
ian_jmp
Level X
Re: What does ill-conditioned regression problem alert mean?
The attached (encrypted) script is taken from the book I helped to write: https://www.sas.com/store/books/categories/usage-and-reference/discovering-partial-least-squares-wit... and it shows the effect. As the correlation between X1 and X2 near +1 (or -1), the problem becomes ill-conditioned. So I assume the data you have did not come from a designed experiment, and that you will need to drop some variables if you want to use MLR.
ian_jmp
Level X
