DaveLee
Column Dialog Box Question
I'm hoping there's a simple answer to this question that been evading me...  I frequently use the Column Dialog Box that allows a user to specify specific columns for user in subsequent analyses.  Is there a way to have a default list of columns automatically appear as selected.  For example, I'm using the Diamonds dataset and would like to run the script and have 'Color' and 'Clarity' automatically show up as selected.  The users could then add to and/or delete from this default list to customize analyses.
PS: Please ignore the dialog at the bottom o f the window  - it's just nonsense carryover that I need to clean up.
ian_jmp
Level X
Re: Column Dialog Box Question
Something like this, perhaps (I didn't bother to put buttons in the UI)?
NamesDefaultToHere(1);
nw = NewWindow("Dialog",
HListBox(
source = ColListBox(dt, all),
destination = ColListBox()
Wait(2);
destination << setItems({:height, :weight});
ian_jmp
Level X
HListBox(
Wait(2);
I use the following code to select in the Col List Box, all of the columns that are currently selected in the data table.  It might prove useful
colListData = Col List Box( nLines( 15 ) ),
colListData << append( dt << get column names ),
// At startup, sselect the columns in the selection box for
// the columns that are selected in the data table
For( II = 1, II <= N Items( All Columns list ), II++,
   If( Column( ii ) << get selected == 1,
   colListData << set selected( II ));
DaveLee
Thanks txnelson​ and Ian@JMP​ for your help.  I have enough to finish the problem now.
