sfkeydel
Weighting within Tabulate
Is it possible to calculate a weighted mean within Tabulate?
Thanks,
Stefan
Jeff_Perkinson
Re: Weighting within Tabulate
Hi Stefan,
You can pre-assign the Weight role to your weighting column in the data table.
To do that use the columns panel on the left side of the data table and right-click on your weighting column and choose "Pre-select Role -> Weight".
Then Tabulate will use that column when calculating statistics.
Jeff
-Jeff
Jeff_Perkinson
Hi Stefan,
Jeff
-Jeff
sfkeydel
Fantastic-- thanks, Jeff!
Stefan
saitcopuroglu
Dear Jeff,
Could you please specify it?
Let's say we have the following table:
How to calculate the weighted mean of ADR as the next column to ADR??
Thank you
Date
Revenue Sold
Rooms Sold
ADR
Monday
$ 60,000
200
$300.00
Tuesday
$ 96,000
300
$320.00
Mean ADR
$156,000
500
$312.00
