To get what you want, I would calculate the values outside of Tabulate, and then just use Tabulate for the formatting.
dt = New Table( "Sample",
Add Rows( 4 ),
New Column( "Group", Numeric, "Ordinal", Format( "Best", 12 ), Set Values( [1, 2, 3, 3] ) ),
New Column( "Subgroup", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [1, 1, 1, 2] ) ),
New Column( "Column 2", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [3, 3, 3, 9] ) )
dtSum1 =dt << Summary(
Group( :Group ),
Mean( :Column 2 ),
Freq( "None" ),
Weight( "None" ),
statistics column name format( "column" ),
Link to original data table( 0 )
dtSum2 = dtSum1 << Summary(
Mean( :Column 2 ),
Freq( "None" ),
Weight( "None" ),
dtSum2:Column 2 << set name( "Column 2_1" );
dtSum1 << Concatenate( dtSum2, Append to First Table(0));
dtSum1 << Tabulate(
Add Table(
Column Table(
Grouping Columns( :Group ),
Statistics( Mean ),
Analysis Columns( :Column 2 )
Column Table( Analysis Columns( :Column 2_1 ), Statistics( Mean ) )
