Weibull Alpha or shape factor from Fit Parametric Survival
I am plotting a Weibull fit to "Time" with a location parameter "B" ("B" has several values) using the Fit Parametric Survival. I have made the "B" variable as numerical and nominal. The parameter estimates from the weibull fit gives me estimates but I can't figure out if these are the shape factors of the Weibull fits to each "B" value. How do I get the shape factor in Fit Parametric Survival plots?
peng_liu
Re: Weibull Alpha or shape factor from Fit Parametric Survival
Please check out "Weibull" from this documentation: https://www.jmp.com/support/help/en/18.1/?os=win&source=application#page/jmp/statistical-details-for...
Weibull shape parameter is 1/sigma, where sigma is from Parametric Survival report.
