  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
olmadriaga
Trouble extracting text from a Text Edit Box JMP 16.1
I am having trouble extracting text from the Text Edit Box in JMP 16.1.  When running the script below, the text that is entered by the user does not show up in the field "title".
maintitle = New Window("Project Name",
	<<Modal,
	Text Box("Enter Project Name for Reports. "),
	PNAME = Text Edit Box("Project Name", set width(80)),
	title = (PNAME << get text() ; ),
	Button Box("OK"),
	Button Box("Cancel")
Show(title);
// This does not work;
Re: Trouble extracting text from a Text Edit Box JMP 16.1
Move your title part inside OK button box
	<<Modal,
	Button Box("OK",
		title = PNAME << get text()
Show(title);
Other option would be to use Return Result with modal window (I think this was already in JMP16)
maintitle = New Window("Project Name", << return result, <<Modal,
	Button Box("OK"),
title = maintitle["PNAME"];
Show(title);
Or if you wish to update it all the time, you can move it to Text Edit Box and add << Script, but I would suggest collecting the results either inside the OK button press or with return result (remember to also check that user pressed OK to close the modal window if you need that).
	<<Modal,
		<< Set Script(title = PNAME << get text()),
		<< set width(80)
	Button Box("OK"),
Show(title);
Edit: Link to Scripting Guide https://www.jmp.com/support/help/en/18.0/#page/jmp/construct-display-boxes-for-new-windows.shtml#ww8...
