キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
timothy_forsyth
Want to know what "<<" means in JSL
What does "<<" signify in JMP scripts?  I'm using JMP 17
 // Get the rows associated with the current excursion label
    excursion_rows = dt << Get Rows Where(dt:"Excursion Label"n == excursionLabels[i]);
Drink deep, or taste not the Pierian spring
1 件の受理された解決策
受理された解決策
Level XIII
Re: Want to know what "<<" means in JSL
it's a message which is sent to an object.
dt is a variable which represents a data table.
The message "get rows where" is sent to this object.
The return value [matrix of rows]  is stored in the variable excursion_rows.
元の投稿で解決策を見る
3件の返信3
Level XIII
timothy_forsyth
Thanks so much!
Scripting Guide is content to quickly go through (no need to read everything, but take a look what it contains), Scripting Guide > Introduction to Writing JSL Scripts > JSL Terminology .
Edit:
<< is same as Send()
biv1 = dt << Bivariate(Y(:weight), X(:height));
biv1 << Fit line;
biv2 = Send(dt, Bivariate(Y(:weight), X(:height)));
Send(biv2, Fit Line);
おすすめの記事
