tom_abramov
Vertical alignment in Lineup Box
If I add some display boxes (blue color in the attached image) to a lineup box with two cols,
and the right display box is lower than the left, I get this empty gaps (red color in the attached image).
What is the way to align the children of the lineup to Top?
Thanks
ian_jmp
Level X
Re: Vertical alignment in Lineup Box
Does this give the behaviour you would like?
New Window( "Spacing",
	Lineup Box( N Col( 2 ), Spacing(0),
		v = Variability Chart( Y( :height ), X( :age, :sex ), Std Dev Chart( 0 ) ),
		d = Distribution(
				Continuous Distribution(
					Column( :height ),Quantiles( 0 ),Summary Statistics( 0 ),
					Horizontal Layout( 1 ),Vertical( 0 ),Outlier Box Plot( 0 )
Wait(2);
Report(v) << verticalAlignment(Top);
Report(d) << verticalAlignment(Top);
9 REPLIES 9
The right side could by another V List Box() that includes the actual display box you want to show followed by a spacer box.
Names Default to Here( 1 );
	Line Up Box( N Col( 2 ),
		Outline Box( "one",
			Table Box(
				String Col Box( "Stuff 1", { "1", "2", "3" } )
		V List Box(
			Outline Box( "two",
				Table Box(
					String Col Box( "Stuff 1", { "1", "2" } )
			Spacer Box()
you may want to try setting the spacing to 0, and then use spacer box() to get the spacing you want. The objects should actually be aligning to the top. What release of JMP are you running?
tom_abramov
Thank you to you both.
Unfortunatly, doesnt work for me.
Attached image and script.
I am using JMP Pro 15.1
@txnelson @Mark_Bailey
		V List Box(
			Distribution(
				Spacer Box()
Your placement of the Spacer Box and the size of the Spacer Box is all that needed to be changed to get your code to work
	Lineup Box( N Col( 2 ), Spacing( 0 ),
		V List Box(
			Distribution(
					Column( :height ),
					Quantiles( 0 ),
					Vertical( 0 ),
			Spacer Box( size( 1, 150 ) )
tom_abramov
Thank you Jim.
When I define exact size of the spacer box, and then the user (I'm developing a dashboard) enlarges the Variability chart, the empty space comes back.
I guess there is no "normal" solution...
ian_jmp
Level X
		d = Distribution(
Wait(2);
tom_abramov
YES! Thanks!
Why not simply use a horizontal list box?
	H List Box(
		dt << Variability Chart( Y( :height ), X( :age, :sex ), Std Dev Chart( 0 ) ),
		dt << Distribution(
tom_abramov
In the real dashboard there wiil be many charts of several kinds and NCols number of the lineup will not be constant.
is perfect
