Martin
Level V
Multiplex MSD 96 Well Plate with Spots Map File
I have used your files and created map file for MSD 96 well multiplex plates with 10 spots per well. I have named the 10 spots "1" to "10" and the well as a whole "11" all in the Part ID column. The Shape ID's are all still the 96 wells using the LetterNumber notation.  This looks GREAT, but when I go to use it, speficying Well as for the Map Role, I only color the entire well, not the individual spots within each well.  How do I access the Part ID portion of the shape file in the Map Role?
Thanks,
Martin
@Mark_Bailey
Re: Multiplex MSD 96 Well Plate with Spots Map File
Yes, that is correct. There is one column that uses the same name as the one used to define the Name and the XY file. You might make an easy-to-use scheme based on concatenation. Easy for you (Well and Spot), easy for JMP (Location). For example:
So the location value is the name used in the Name and the XY shape files. But the scheme is entirely up to you. I tried to make my original scheme as straight-forward and easy as possible because I intended to release it in the JMP Community.
8 REPLIES 8
Graph Builder uses shape files to render data with a geometric interpretation. The shapes are defined by two JMP data tables (Name and XY). JMP published the specification for the required format of these files. JMP installs with many pairs of shape files for geographical entities. But you can make your own shape files for any custom geometry. You just need to follow the specification and it should work without any problem.
I used the specification to make the shape files for standard 96-well plates. The specification provides the means for each shape to be comprised of more than one part. So you could make your own shape files with 10 parts (spot) per shape (plate well) to display your nested data.
Martin
Level V
So the shapes that are referenced in your data table are based on the second column in the Name file, right?  This is a clip from my Name file:
but what I have done is add 10 additional Part ID's (one for each spot within each of the 96 wells) for each Shape ID in my XY file.  So for each Shape ID in the XY file, I have 11 Part ID's (10 for spots and 1 for the outer circle).  My final graph looks like this:
In order to use the individual spots, instead of the outer 96 wells, how do we use the combination of Well Number and Spot Number?  I thought it was with different Part ID's, but can't seem to use them.
I apologize. I made a mistake. The map of a response value to a shape is key. So you should not use the part feature for each spot. Each spot should be its own shape. Then the mapping will work.
Martin
Level V
Ok. What is the Part ID used for then? Only for non-contiguous areas, e.g. the US with the continental US, Hawaii and Alaska all being part of the same country?
So Shape ID would represent country, and Part ID would just be the non-contiguous areas?
Thanks for the help.
Yes, that is the idea. But you do not have dis-contiguous areas. Part ID will always be 1.
The shape corresponding to a single response is a spot in the well. Each shape has presumably just one part. This one-to-one mapping is the same one that I used for the original plate well.
Martin
Level V
If I understand you @Mark_Bailey, Each of my 10 spots within each of the 96 wells will get its own Shape ID (960 in all). This means I need to give each shape a unique name in the Name file. Normally, my analyses have two columns: one for Well, e.g. B5 or H10, and one for spot, e.g. 1 or 8. I guess I will need to make a new column in my analysis table that uses a Well/Spot identifier and I can match up with the map Name file second column. Is that correct? Or, is there a way to have two columns in the map Name file represeting Well and Spot that can be used in the map role in my analysis table?
From what you’ve described, it sounds like your shape file is correctly set up with 10 individual parts (spots) per well, labeled 1–10, plus the well as a whole labeled “11” in the Part ID column. The challenge you're facing is that when you assign “Well” as the Map Role, JMP only recognizes the entire well and not the individual spots within it. This happens because JMP uses the value in the Map Role to match what's in the Name column of your shape file, not the Part ID column.
To visualize individual spots within each 96 well plate template, you’ll need to ensure that each spot (i.e., each part within a well) has a unique identifier that combines both the well and spot information in a format that aligns with your data table. For instance, you might concatenate the well position (like A1, B1, etc.) with the spot number—something like “A1_1”, “A1_2”, etc.—and use that combined value in both the Name column of your shape file and your data table. Then, in Graph Builder, you can assign this combined value as the Map Role and JMP will match each spot individually.
I ran into a similar situation with a cytokine panel where I needed to display signal intensity per spot across a 96 well plate template, and using this naming strategy worked perfectly. If you need a visual starting point or inspiration, this site  offers a variety of templates that helped me double-check my layout logic.
