tarkan_bih
Vector Plot in JMP
Hi, I am trying to do a vector plot in JMP but I have not been able to. The following POST had a blog on it but it looks like the blog has been archived. I am doing some data exploration and I have my dx and dy columns figured out. Is there a way to do this in graph builder? I vaguely remember that you have to updated customize graph below to make this happen (see image below)
Level XIII
Re: Vector Plot in JMP
With a local data filter, you have to get the non-excluded rows on your own:
dt = Open( "$DOWNLOADS/ChicagoWind.jmp" );
biv = dt << Bivariate(
	Y( :Lat1 ),
	X( :Lon1 ),
	Show Points( 1 ),
ldf = biv << Local Data Filter(
	Add Filter(
		columns( :STN ),
		Where( :STN == "BIV" )
Report( biv )[FrameBox( 1 )] << Add Graphics Script(
	Pen Size( 2 );
	myRows = ldf << Get Filtered Rows;
	For Each Row(
		If( Loc( myRows, Row() ),
			Arrow( {:Lon1, :Lat1}, {:Lon2, :Lat2} )
Level XIII
You can open the jmp file in the post that you linked.
wow, amazingly easy:
By the way, the development team seems to investigate if it is worth to add such a feature to Jmp by default:
Add vector fields to Graph Builder
tarkan_bih
 Thanks! One thing I noticed when using 'customize...' is that when I use local data filter does remove the other vectors drawings as seen below. Is there way to only have it draw based and filter based on what is inside the local data filter
Level XIII
The easiest way : use a global data filter.
then you can restrict the vector plot to the non-excluded rows by:
For Each Row( If( Not( Excluded() ), Arrow( {:Lon1, :Lat1}, {:Lon2, :Lat2} ) ) );
Level XIII
	Y( :Lat1 ),
	X( :Lon1 ),
	Show Points( 1 ),
	Add Filter(
		columns( :STN ),
	Pen Size( 2 );
	For Each Row(
