nicoleaba
Value Ordering of a column based in Ascending Date for another column
Hi everyone,
I want to know if there is a way to assign the value ordering labels of one column based in another column that would have a date sorted ascending via scripting.
Here is a little example of the columns. I want to have my ID's order by date.
IDDate
71220G101/04/2018
80102G101/05/2018
80209G102/19/2018
I need that beacuse I need to do a graphic in Control Chart Builder by ID, but to see the trend in time also. I know if build a XBar chart by itself it would accomodate my values as they appear in the data table, but Control Chart Builder won't.
Is a big data table so any jsl code for doing this would be great.
Thanks in advance.
pmroz
Re: Value Ordering of a column based in Ascending Date for another column
This code will work:
dt = New Table( "Test", Add Rows( 3 ),
		New Column( "ID", Character, "Nominal",
		Set Values( {"71220G1", "80102G1", "80209G1"} )
	New Column( "Date", Numeric, "Continuous", Format( "m/d/y", 12 ),
		Input Format( "m/d/y" ),
		Set Values( [3597868800, 3597955200, 3601843200] )
dt << sort(replace table(1), by(:Date));
id_values = dt:ID << get values;
dt:id << Set Property( "Value Ordering", id_values );
If you have multiple dates for a given ID you'll have to take a different approach.
uday_guntupalli
Level VIII
@nicoleaba
        Sorting the table by dates could work. So something like this:
dt = Current Data Table();
dt1 = dt << Sort( By( :Date ), Order( Ascending ) );
Best
Uday
pmroz
nicoleaba
It worked perfectly!
Thank you so much @pmroz.
