hagaishalev
JMP14 Unable to fetch results set
Trying to get data from SQL server with stored procedure failed in JMP14 and succeed in JMP8 and JMP9.
in JMP14 there is an error:
JMP Alert: Unable to fetch results set.
JMP AlertJMP Alert
and there is no result table (show(t1); return "t1=.)
I get the same issue in JSL and with "Databse Open Table"
The stored procedure output countains few empty sets, which need to be skkiped. Apperntly the JMP8 is doing it automatcly, but not the JMP14.
SQL outputSQL output
Using Python I overcome this issue by cursor.nextset() untill I get a set with values.
I tried variety of formats, including:
dbc = Create Database Connection(
       "DSN=*******;UID=*****;PWD=*********;APP=JMP;WSID=SYS-CB2;DATABASE=Iserve;LANGUAGE=us_english;"
t1 = Execute SQL( dbc, "exec PL_RawData_restart '50110326','08/01/2018','08/16/2018' " );
RawData_dt=Open Database("DSN=*******;UID=****;PWD=*****;APP=JMP;WSID=SYS-CB2;DATABASE=Iserve;LANGUAGE=us_english", "exec PL_RawData_restart '48300134', '2018-07-17', '2018-07-31'");
gzmorgan0
Re: JMP14 Unable to fetch results set
I have not used a stored procedure, but here is a link to a JMP blog March 2017 for JMP 13
https://community.jmp.com/t5/Discussions/Database-stored-procedure/td-p/36885
another regarding NO COUNT ON for JMP 11
https://community.jmp.com/t5/Discussions/JMP11-MSSQL-Stored-Procedure-Call/td-p/10906
a note on why a stored procedure worked in JMP 8 and not in JMP 11
https://community.jmp.com/t5/Discussions/Importing-SQL-using-a-temp-table/td-p/11760
Hope these give you some leads.
hagaishalev
Thank you! There might be no solution for my issue from the JMP side.
