Level XIII
Value Colors - same color for a block of values?
When defining colors via value colors, is there an easy way to define the same color for a block of (e.g. 100) adjacent values?
I can select the block via Shift Click, but how to apply the color.
Selecting the respective rows and changing the color manually is no option because I want the rule to be applied dynamically after data changes.
Thierry_S
Re: Value Colors - same color for a block of values?
Considering your advanced level in this Discussion forum, I am unsure if this suggestion will help.
Have you considered creating a grouping formula (e.g., Quantiles) to which you could assign colors?
If(
	:X <= Col Quantile( :X, 0.25 ), 1,
	Col Quantile( :X, 0.25 ) < :X <= Col Quantile( :X, 0.5 ), 2,
	Col Quantile( :X, 0.5 ) < :X <= Col Quantile( :X, 0.75 ), 3,
	4
// OR a classification based on Rank //
Round( (Col Rank( :X ) * 10) / N Rows(), 0 );
These are just workarounds.
Best,
TS
Thierry R. Sornasse
Thierry_S
If(
	4
Best,
TS
Thierry R. Sornasse
Level XIII
An auxiliary variable is a good idea, thanks :)
Level XIII
While playing around I found out that for long lists the values in a GraphBuiler plot don't match the values defined via Value Colors ( TS-00045154). According to Jmp support, this is a known issue and will be fixed in Jmp 18.
Workaround: define the colors via JSL:
View more...
dt = Open( "$SAMPLE_DATA/Aircraft Incidents.jmp" );
locs= AssociativeArray(dt:Location << get values) << get Keys;
myMax=N items(locs);
colorList = Transform Each({i},As List(Transpose(1::myMax)),
                Substitute(Expr(__a__ = __b__), Expr(__a__), locs[i], Expr(__b__), -15000000 +i)
dt:Location << delete property("Value Colors");
Eval(substitute(Expr(dt:Location << Set Property("Value Colors",__cols__)),Expr(__cols__),Name Expr(colorList)));
Graph Builder(
                Size( 490, 458 ),
                Variables( X( :Location ), Color( :location ) ),
                Elements( Points( X ) )
