TONYMA
V list box and H list box
dear all
i want  to run JSL to put data table and oneway into one report, but it does not work
the jsl which i wrote as below:
rep=dt<<report
win=New Window( "Example",
  V List Box(rep="$SAMPLE_DATA/Big Class.jmp",
  A=Oneway( Y( :height ), X( :sex ), Means( 1 ), Mean Diamonds( 1 ) ); ));
where is my wrong?
you are your god.
Re: V list box and H list box
Your attempt to reference the data table in your display window is not the correct syntax.  All functions and messages that are available for a data table are listed in the the Scripting Index under the the Data Table subsection
     Help==>Scripting Index==>Data Table
The correct syntax to use is:
rep = dt << report
win =
	V List Box(
		dt << new data box(),
		A = Oneway(
			Y( :height ),
			X( :sex ),
			Means( 1 ),
			Mean Diamonds( 1 )
I also strongly suggest that you read the first 3 chapters of the Scripting Guide.  It will speed up your learning of JSL
     Help==>Books==>Scripting Guide
rep = dt << report
win =
	V List Box(
		A = Oneway(
			Y( :height ),
			X( :sex ),
			Means( 1 ),
			Mean Diamonds( 1 )
