DBiber
Using specific row values for use in a formula
Hey there,
I'm sure this has been covered in the past, but I had trouble finding something that matched.  In a new column I would like to calculate Average release for condition 9 as compared to the same time points in the control.
Something like this logic:
When Condition # =! "Control",
Divide average release by the corresponing average release (by Time Point) in the Control.
Eventually I would like to perform F2 dissolution comparison calculations in a column but need to start with calling a specific row first.
Re: Using specific row values for use in a formula
Try this formula
If( :Condition # == "Control",
	:Average Release / Col Mean( If( :Condition # == "Control", :Average Release, . ), :Time Point )
uday_guntupalli
Level VIII
@DBiber
   I am presuming you are looking for something like this. But I am not sure I follow your question - so let me know if this is not what you want.
SR = dt << Select Where(:Condition # == "9") << Get Selected Rows;
Show(SR); // Print selected rows to log
Denominator = Mean(:Time Point[SR]); // Correct as needed for your formula
dt << Clear Select;
NewCol = (dt:Average Release << Get Values)/Denominator;
dt << New Column("Test",Numeric,Continuous,<< Set Values(NewCol));
Best
Uday
Try this formula
