nathan-clark
Using new :Name() nomenclature with variable
I am really likeing the shift from :Name("column name") to :"column name"n, especially with how datatables can reference columns easier. But I am having trouble getting it to work when the column name is a variable.
dt = currentdatatable();
colName = "Column Name";
//old way works fine
Column(dt,colName) << set name("new column name");
//if it's not a variable it works
dt:"Column Name"n << set name("new column name");
//as a variable, the syntax is lost on me
dt:colName << set name("new column name") // nope
dt:colName||"n" << set name("new column name") // nope
dt:colName||n << set name("new column name") // nope
I am sure it's something simple ... but it's just not coming to me. The old way works fine so I can still keep scripting away, but this new method is much cleaner, and I'd like to use it everywhere :)
Re: Using new :Name() nomenclature with variable
Running on Windows 10 with JMP 15.2.1 I get the slightly different results
dt = Open( "$SAMPLE_DATA\big class.jmp" );
colName = "height";
Show(
	dt:Height[1],
	dt:Name( "height" )[1],
	dt:"Height"[1],
	dt:"Height"n[1],
	Column( dt, "Height" )[1],
	Column( dt, colName )[1],
	dt:colName[1]
dt:colName << set name( "New Column Name" );
Which returns
dt:Height[1] = 59;
dt:height[1] = 59;
dt:Height[1] = 59;
dt:Height[1] = 59;
Column(dt, "Height")[1] = 59;
Column(dt, colName)[1] = 59;
dt:colName[1] = 59;
Scriptable[]
with the data table having the following names after the script was run
colName = "height";
Show(
	dt:Height[1],
	dt:"Height"[1],
	dt:"Height"n[1],
	dt:colName[1]
Which returns
dt:Height[1] = 59;
dt:height[1] = 59;
dt:Height[1] = 59;
dt:Height[1] = 59;
dt:colName[1] = 59;
Scriptable[]
Jeff_Perkinson
I believe that the ""n construction is only intended for when you have need to use a character literal in the statement itself. So, it's not necessary to try to get the ",n" appended to it.
As for your testing this works for me:
dt = open("$SAMPLE_DATA/Big Class.jmp");
colName = "height";
dt:colName << set name("new column name");
-Jeff
Jeff,
I have done multiple searches in an effort to find the documentation on ""n documentation. Do you have the specific reference on it?
After some googling figured out at least one place where I had seen that syntax before:
Automating the Data Curation Workflow (2020-US-45MP-620)
which provides link to here:
JMP16.0 - JSL Syntax Guide - Names
nathan-clark
Thanks @txnelson and @Jeff_Perkinson ... That is definitely a simple fix :)
I feel I ran into troubles with that a while ago and never thought to try it again!
Level XIII
When was  the :columnName syntax introduced?
Is there further documentation why the same syntax was used for a) the Column object and b) the "As Column" reference, e.g. inside a formula?
Why does Name Expr (As Column()) return the :column Name thing - which again can be used for both purposes?
