Zappy
Using R script in JMP
Dear Community,
I have read a past post on this topic regarding using R Init(), R Send()....etc to send data from JMP table and utilize the R to peform the task.
However it does not show more in details on how to do it.
For example I have a R script attached and would like to use this R Script to run in JMP.
How should it be modify or scripted in JSL using those RInit()....etc?
Thanks to advise.
B.r,
Chris
mlo1
Re: Using R script in JMP
Did you check out the R send () and R get () commands to send the parameter and get the result back to and from your function.
The R-Code needs to be part of the R Submit().
There are examples how to structure it in the help files.
You need to check the data types as well.
https://www.jmp.com/support/help/en/17.2/?os=win&source=application#page/jmp/conversion-between-jmp-...
https://www.jmp.com/support/help/en/17.2/?os=win&source=application#page/jmp/r-examples.shtml?_gl=1*...
