steidley
Using Hex values for the Y-Axis Labels
In JMP 18,
I have a set of data grouped by category.  The X-Axis holds the category (character) and the Y-Axis is the value in hexadecimal.
I have three columns of the data:
1) original value as hex
      - character nominal
      - :mv
      - eg. 0x066F
2) :mv converted to a decimal number
       - continuous number format
       - :mv_number
       - eg 1647
3) :mv_number converted back to hex, but without the 0x
       - character - nominal
       - :mv_hex_label
       - eg 066F
Is there a way to graph this data so that the labels for the tick marks on the Y-Axis are in Hex, and in numerical order as opposed to alphabetical order?
Re: Using Hex values for the Y-Axis Labels
Take a look at Value Labels column property
You could also look at displaying the Hex values and then using Value Ordering column property to set the order in the graph.
Level XIII
as a third option, use the hex labels, and in addition drag the numeric column into this drop zone - to use it for ordering.
The same can be done via right click / order by  / Others ...
just takes a few seconds - independent of the number of entries.
steidley
Reading all three suggestions got me in the ballpark for an answer.  Thank you!
What I ultimately have done is to set up the Y axis with the original data column 'mv'.  I then drug the decimal version of the data next to the Y axis and dropped it in the "Order By" section:
This did in fact order the values correctly.
Now, my only lament is that I have lost the sense of scale.  Values like 03DB are right next to 0668.  This has lost a lot of the intuition about data points that exhibit bi-modeality.
Here, you can see that data passes in one region and fails in other regions:
Since exact hex values are not critical, I think what I will do is explore creating reference lines to let me know where 0x100, 0x800, 0xF00 are...
Level XIII
Happy to see that you like the "order by" functionality.
Level XIII
To add some structure, you can use nested levels on the Y axis:
dt = New Table( "Hex",
	Add Rows( 20 ),
	New Column( "Hex",
		Character,
		Set Values(
			{"0x0EB6", "0x00E0", "0x0052", "0x0059", "0x0052", "0x0037", "0x002E",
			"0x0025", "0x0C74", "0x0C6B", "0x0C5E", "0x0C55", "0x0C2E", "0x0C19",
			"0x0BE7", "0x0B9A", "0x0B8E", "0x0B53", "0x0B30", "0x00B5"}
	New Column( "Hex Group", Character, "Nominal", Formula( Substr( :Hex, 1, 4 ) ) ),
	New Column( "decimal",
		Formula( Hex To Number( Substr( :Hex, 3 ) ) )
dt << Graph Builder(
	Variables(
		X( :decimal ),
		Y( :Hex Group, Order By( :decimal, Ascending) ),
		Y( :Hex, Position( 1 ), Order By( :decimal, Ascending ) ),
		Color( :Hex Group )
	Elements( Bar( X, Y( 1 ), Y( 2 ) ) )
