BabyDoragon
Using Character Variables with SetData in Tree Nodes
I hope to use "Set data" to configure the information in the tree node. However, the variable usage does not meet my expectations. As shown in the JSL below, I want to record the text "Test" in the variable Title and set it into C1, so that Show(C1) displays as C1 << Get Data = {"Test", "", 1};
The results of using a variable (C1 situation) and directly using text data (C2 situation) for setData differ, which leads to errors when I later attempt to retrieve the data. How can I use a variable to set data so that I can obtain the same result as directly setting "Test" with setData?
Title = "Test";
C1 = Tree Node( Title );
C1 << SetData( {Title, "", 1} );
Show( C1 << Get Data );
Show(( C1 << Get Data )[1] );
C2 = Tree Node( "Test2" );
C2 << SetData( {"Test2", "", 1} );
Show( C2 << Get Data );
Show( (C2 << Get Data) [1] );
Re: Using Character Variables with SetData in Tree Nodes
You will have to evaluate the list, for example
Title = "Test";
C1 = Tree Node(Title);
C1 << SetData(Eval List({Title, "", 1}));
Show(C1 << Get Data);
// C1 << Get Data = {"Test", "", 1};
Title = "Test";
BabyDoragon
Thank you for swiftly and accurately resolving the issue I encountered.
