KST-CPT
User input dates
I have a column of date time in a table.  When I run my script I want a dialog box to come up (calendar selection would make selection easier), which asks for a start date and end date.  They can be seperate dialog boxes, or they can be the same, either would suffice.  I want to store these dates in variables so that I can "select where" to create a subset within or around these dates.
I have tried numerous approaches, the one I like best:
startDate = new window("Start Date of Data",<<Modal, numbereditbox(today(),20,<<setformat(Format("m/d/y", 12)),Button Box( "OK", StartDateRT << get ), Button Box( "Cancel" )));
Show(StartDateRT);
show(StartDate);
gives me this result in the Log:
StartDateRT = DisplayBox[];
StartDate = {Button(1)};
How do I get the selected date so that I can use it later?
Re: User input dates
Use a Calendar Box().  Go to
     Help==>Scripting Index==>Calendar Box()
for details.
Here is the JSL example from the Help entry
New Window( "Calendar Box Example", Calendar Box() );
for details.
