UserID16644
Level V
User Input Tabulate Column
Is it possible to have a user-based column when tabulating data? I have a tabulated table but the grouping columns need to be based on the user input. I can't think of ways to do it, is it possible? pls help
Re: User Input Tabulate Column
JMP has the functionality to request user input and then pass that information into whatever scripting is required.  I recommend that you take the time to read through the Scripting Guide.
Here is a very simple example to do what you want.  Far better interfaces can be developed, but this should give you a start
// Open Data Table: big class.jmp
// → Data Table( "big class" )
nw = New Window( "Col List Box Example",
	Text Box( "Select the Grouping Columns" ),
	Col List Box( all, width( 250 ), maxSelected( 1 ) ),
	fontobj = lb = Col List Box( character ),
	OKbb = Button Box( "OK",
		theColumns = lb << get items;
		nw << close window;
		Tabulate(
			Show Control Panel( 0 ),
			Add Table(
				Column Table( Analysis Columns( :height, :weight ), Statistics( Mean ) ),
				Row Table( Grouping Columns( eval(theColumns) ) )
		nw << close window;
		Tabulate(
			Add Table(
UserID16644
Level V
Not sure if it's my JMP Version (JMP15) but it's not working for me
It works fine under JMP 15, running Windows 10.
Here is the first screen
I then select columns Name and Age and move them into the selection area
Finally I click on OK and get the following results
UserID16644
Level V
Worked well. Thanks!
