UserID16644
User Input Tabulate Column
Is it possible to have a user-based column when tabulating data? I have a tabulated table but the grouping columns need to be based on the user input. I can't think of ways to do it, is it possible? pls help
Re: User Input Tabulate Column
JMP has the functionality to request user input and then pass that information into whatever scripting is required.  I recommend that you take the time to read through the Scripting Guide.
Here is a very simple example to do what you want.  Far better interfaces can be developed, but this should give you a start
// Open Data Table: big class.jmp
// → Data Table( "big class" )
nw = New Window( "Col List Box Example",
	Text Box( "Select the Grouping Columns" ),
	Col List Box( all, width( 250 ), maxSelected( 1 ) ),
	fontobj = lb = Col List Box( character ),
	OKbb = Button Box( "OK",
		theColumns = lb << get items;
		nw << close window;
		Tabulate(
			Add Table(
				Column Table( Analysis Columns( :height, :weight ), Statistics( Mean ) ),
				Row Table( Grouping Columns( eval(theColumns) ) )
		nw << close window;
		Tabulate(
			Add Table(
UserID16644
Not sure if it's my JMP Version (JMP15) but it's not working for me
It works fine under JMP 15, running Windows 10.
Here is the first screen
I then select columns Name and Age and move them into the selection area
Finally I click on OK and get the following results
UserID16644
Worked well. Thanks!
